Home > Wheels & Tyres > Tyre Life - Continentals |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6260 |
not sure if it helps too much but purely road use I would be expecting +60k miles from them from my experience.
30th Mar 2015 2:41pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
mine are half worn @ 36,000 miles BUT they're going hard. they get noisy are start to go out of shape so i'll change mine at around 40k
30th Mar 2015 2:45pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1561 |
36k before I sold my last 90. Tyres looked good at point of sale, I reckon at least another 10k.
30th Mar 2015 3:09pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2520 |
Sounds like I'm definitely doing something wrong then, what pressures are you all running them at? Mine do seem to be wearing more in the middle of the tread than the edges, but I've only got them at 28 front and 30 rear, so hardly excessive I would say.
Or maybe it's the forest roads that are doing it, they are pretty hard on tyres. |
30th Mar 2015 3:32pm |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 714 |
X2 |
30th Mar 2015 8:11pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Mine are down to 12mm after 9500 miles [They are 14mm when brand new] .. so by that ratio to get to 5mm should be around the 43,000 mile mark
Pressure - I run mine at 30 fr and 38 rr Guns and Landrovers .... anything else is irrelevant. |
31st Mar 2015 12:32pm |
On a 90, LR stipulate 30 Front, 38 Rear. An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
31st Mar 2015 4:25pm |
Where do you fine that information? My book is blank for both 7.50 and 235.
I've been running my 7.50s at 34PSI / 38PSI (110) which seems about right, went to check the farm one yesterday which was at 44/50 which made me wince a bit. I presume there's a reason they're that high but it would explain why it feels so hard. |
31st Mar 2015 6:47pm |
