Home > Wheels & Tyres > Restoring white lettering |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
I know IT is not everybody thing but I like the white letters on my BFG AT tyres but they are looking quite faded anybody recommend something to freshen it up?
27th Mar 2015 12:19am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19531 |
Tyre pen? Would take a bit of time and patience though.
27th Mar 2015 12:30am |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 |
Tyre pens are a complete PITA to use, unless you can physically remove the wheel & lay it down flat to work on.
TT "Ease your worries, Clear-up your woes, Go into your garage & put stuff into rows." |
27th Mar 2015 1:05am |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 |
I've tried rubbing the letters with some fine wet sandpaper with great success.
27th Mar 2015 7:11am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
You will find that the white part is actually moulded into the tyre wall like a skin under the outer skin, all the way around, so as mentioned rubbing with abrasives it will always be there.
If that makes an sense....? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
27th Mar 2015 7:54am |
One of the soft pan scrubbers or a magic sponge
I'd be careful of using any chemicals on the sidewalls. |
27th Mar 2015 9:30am |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
I use wonder wheels on our 300tdi, makes the lettering stand out a treat. Mrs Grumpy loves it
27th Mar 2015 2:52pm |
