Home > Td5 > 53 PLATE TD5 CAMSHAFT |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16858 |
You probably mean camshaft not crankshaft.
13th May 2014 11:00pm |
Raptor Member Since: 28 Mar 2014 Location: barnsley Posts: 10 |
OOOPS Yes i mean camshaft blackwolf, apologies, edited mistake.
14th May 2014 6:38am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6031 |
When you say wear, is there a groove? or a dark mark? or have you compared your cam to a new one and the lobes are much smaller?
14th May 2014 8:02am |
There are grooves in a couple of the lobes, and slightly "flat".., the "bearings" on the rocker shaft are also worn, just worried now what further probs may occur until i get it sorted, i still have to use it daily,, paranoia easily creeps in, especially after having a D2 a while ago that had some rather odd tendencies to say the least
14th May 2014 8:09am |
ongoing lol
9th Jun 2014 2:29pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Two quick things, can you post some pictures for me to look at and have you noticed any problems with the general running of it?
9th Jun 2014 7:04pm |
i didn't take any pics, i just put everything back on because i need to use it, (i've just got hold of a replacement rocker shaft.).
General running is becoming somewhat different, fires up instantly every time, but if i pull away straight away she hardly moves for about 5-10 seconds, literally crawls, then she will suddenly burst into life juddering and shaking the hell out of itself, then she runs ok, quite a shock to any unsuspecting passengers lol. There's what seems to be a slight misfire that is apparent mostly when slowing down or speeding up, at steady consistent revs its not really noticeable, she is also getting more "tappety" I've kind of got used to it and seem to have adopted a totally different driving style to accommodate the "issues", i drive too and from work in it now and dare not push my luck anymore to go much further than that 10 mile or so round trip. I have also noticed the engine "smells" very warm within minutes of driving, i've also developed a rather bad habit of sniffing around the front of the bonnet every time i stop and get out but it is a very hot oily smell, but she loses no fluids or burns any off.. I just don't know to be honest fatboy slim, the inconvenience and the fact i've only had it a couple of months is annoying me more than anything, could well do without it the trials and tribulations, i expect jobs to do with landrovers, comes with the territory, but at the minute i'm just seeing 7 grand sat idle really, frustrating. |
9th Jun 2014 9:21pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Probably not much help I know, but one of my previous td5 90's had a problem similar to what you've just described in that on a cold start, for the first 30 secs to a minute it would not rev, no amount of throttle jabbing would get it above tick-over, if I floored the loud pedal it would judder and shake but the revs would not go over 800 or so, it would also emit clouds of white/grey smoke during this time.
Coincidently though, on the same car, I also had a problem with a worn camshaft, in my case it was due to the vacuum pump on the alternator, the centre rotor had broken up causing tiny bits of hard steel to get into the oilways. The head was replaced to cure the camshaft problem but it was never really right after that, it was always noisy. Thinking about the first issue, I got a very similar effect on my Disco 3 when I ran it with the MAF sensor effectively out of circuit by removing the pipe from the air filter box to the turbo, (with the top cowl off to test after replacing the aux belt,) so I wonder if it could be a gummed up MAF sensor causing the problem? |
9th Jun 2014 10:10pm |
In all honesty, if it uses no fluids , runs on 5 cylinders and starts every time I really wouldn't worry to much . Make no doubt about it, these little engines are as hard as nails . We run them on opencast sites where they never see a surface that resembles a road of any sort, they get cooked, drowned, airfilters sucked inside out so they breath in coal dust and grit for months on end and they still run ok. Drive it till something goes wrong...by the way your no power from startup issue sounds a lot like a knackered airflow meter.
9th Jun 2014 10:17pm |
Everything is of some help Clive, it's always good to have an insight into similar issues others may have had, gives a base to start from and also helps verify what may already have been considered but possibly dismissed.
I agree with both comments re maf, which is one of those thoughts i discarded, mainly due to my camshaft obsession and putting any and probably all other issues down to that, but i shall now revisit that I'm probably over analyzing it fatboy slim, but i'm like a dog with a bone, it's on my mind and i have to sort it, just for peace of mind, i've missed 2 falconry fairs due to worry of driving the distance and making it worse, i have another raptor fair coming up this weekend over in Hemsley north yorkshire, just a couple hours drive away, but i doubt i will make the journey lol. The things are built to take some hammer, well i like to think so, just a bit more complicated with all the tickery now planted in them, i'm still amazed at a defender having central locking and electric windows lol, never mind ecu's and plug in diagnostics etc |
9th Jun 2014 10:53pm |
UPDATE
Job done, i haven't changed the cam, i've "ground polished and buffed" the offending marks out of the "damaged" lobes, taken most of the day, i have renewed the rocker shaft, that just wasn't worth messing about with. The difference in running is very much noticeable, and definitely quieter, |
27th Jun 2014 9:42pm |
Raywin Member Since: 27 Feb 2015 Location: North Yorkshire Posts: 48 |
Hi I am new to this forum but I also found my TD5 camshaft was damaged on one lobe and the corresponding injector rocker was scored, last week I changed the rocker for a second hand one I bought off e-bay, I want to use this as a stop gap until I can change the cam shaft and full set of rockers might even do a big job on the engine when the weather gets better.
When I read this thread I wondered if the cleaning and polishing you did worked, is it still OK now that a few months have passed? |
27th Feb 2015 12:06pm |
