Home > Td5 > Aircon Fan |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
Aircon fan on full time usually means an overheating issue. Mine was a faulty sensor.
You say no fault codes, did you get the engine temp from the ECU? What was that reading? It wasn't me! |
1st Feb 2015 12:54am |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 621 |
I had similar - the AC fan cuts in when the engine overheats/coolant low. I had similar symptoms on a V8 - the coolant level had dropped a bit low. JB
@Lodelaner Instagram Youtube greenlaning and other LR related content |
6th Feb 2015 10:25pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Even when turning the engine on from a cold start, the fan comes on. It's daintily not an overheating issue.
6th Feb 2015 11:44pm |
Does the ECU know its not overheating? Mine had no faults stored, ran constantly from cold and ran normally after the sensor swap. It wasn't me!
7th Feb 2015 10:08pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
It is my understanding that the A/C fan on the Td5cuts in at 28 degrees ambient temperature I think it gets its reading from the sensor in the air filter box, could this be faulty ? Could be worth unplugging it and seeing what happens. 2005 Td5 90 XS
Steve |
7th Feb 2015 10:24pm |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 276 |
I had exactly the same problem. Had the air con re-gassed (even though it was running very cold) and that fixed it.
Tony |
9th Feb 2015 1:51pm |
