Home > Tdi > R380 Gearbox Advice Please |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2872 |
If your going to do it , do it once upgrade parts AShcroft all day
29th Jan 2015 9:31pm |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 |
Yep, happy to upgrade to suffix L as I believe it has a stronger main shaft? Not sure i need the rear HD support bearing or the 5th gear ratio upgrade. As I say it's not tuned in any way and I don't tow, happy to consider it though.
The question would be, do I need the suffix L box and the HD support bearing....not sure? Don't have any knowledge of this stuff? 2007 Defender Puma Tonga Green 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
29th Jan 2015 9:53pm |
Speak to Dave at Ashcroft
29th Jan 2015 9:54pm |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 254 |
Hi,
PM me your number, will call you tomorrow to discuss, Dave Ashcroft Dave |
5th Feb 2015 10:48pm |
Thanks Dave, will do. 2007 Defender Puma Tonga Green
5th Feb 2015 11:07pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5738 |
I think my g/box failure was caused by the 5th gear bearing, so when I did mine, I opted for the bearing upgrade. 1999 Defender TD5 110
6th Feb 2015 9:13am |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
Hi, what did you decide to go for? I need to make a decision on mine.
6th Feb 2015 12:35pm |
Having spoken to Dave today I'll be going for like for like gearbox Suffix J and input gear/bearings. No requirement for upgraded HD bearing based on what I use it for.
Starting the strip out this weekend. Issue with 5th gear but new one should be good for 80/90k miles so good for me. Thanks also to Dave for your advice. 2007 Defender Puma Tonga Green 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
6th Feb 2015 5:54pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 487 |
I would hope it will last more than that! 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
7th Feb 2015 9:51am |
5th gear bearing Dave not the gearbox itself. Not sure when mine actually failed but the Defender had 102k on it when I bought it so sounds about right.
Only time will tell but I'm only covering upto 3k a year on mine so should last a while. 2007 Defender Puma Tonga Green 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
7th Feb 2015 10:20am |
