Home > Td5 > Front Seats.. |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Dunno about the middle seat,take the passenger seat out,runners probably full of crap,clean it, lube it,(I use white grease) then hey presto,a working seat. Pov.spec,ftw. 2006, 110,TD5.
28th Jan 2015 11:00pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
We get quite a few seats stuck in cars at work,often got a coin or pen lid stuck in the runners ! 2005 Td5 90 XS
Steve |
28th Jan 2015 11:23pm |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 570 |
The middle seat isn't too dificult to remove.
Lift up the base,it's just clipped in like the driver & passenger.There are 4 bolts holding it in.IIRC. Simples. |
29th Jan 2015 9:49am |
timtom1 Member Since: 10 Jul 2012 Location: Lancashire Posts: 148 |
Thanks all I will give those ideas a try 2001 90 TD5 CSW Alveston Red Manual
29th Jan 2015 1:01pm |
Ahh I can't get to the rear bolts because I can't slide the passenger seat forward, any ideas? 2001 90 TD5 CSW Alveston Red Manual
29th Jan 2015 1:55pm |
A torch and a long thin stick to see if you can disslodge anything in the tracks and if there's nothing there then brute force
29th Jan 2015 2:21pm |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 |
The rear bolts on the middle seat can be a bit of a beggar to get to I have an extra long 3/8 drive extension thatI use, regarding the passenger seat make sure that the seat slider lever is lifting all the way up and disengaging in the slider.s
Uncas |
29th Jan 2015 3:50pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
If you can get it to me I'll move it. A defender front seat doesn't stand a chance against my 18 stone supermodel figure and iron grip on the front bar get angry with it |
29th Jan 2015 6:09pm |
lol bit far yeah I will have another bash at it tomorrow 2001 90 TD5 CSW Alveston Red Manual
29th Jan 2015 7:20pm |
I've managed to sort (in a way) the passenger seat.. it appears to be the spring mechanism, so when a person is sat on it, its really hard to move. But when you are outside the vehicle and push it forward while holding the back of the seat it moves freely. Now to have ago at removing the centre seat.. 2001 90 TD5 CSW Alveston Red Manual
30th Jan 2015 10:46pm |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 426 |
Centre seat is easy, once you know how.
You have to take the centre access panel off, under the rubber matt once you take the centre seat base off. Four Philips screws for access panel . Take front bolts out first. To get rear bolts out you need a t6 star drive and a 14mm socket underneath, using the access hatch. A torch is a nessecity and you need to take the driver and passenger base seats off get good access . The other bolts hold the seat belt mounts. It's easy once you have done it. I did mine over Christmas , full 1/2 exmoor re trim and heated seats |
30th Jan 2015 11:34pm |
Thanks I think I have a T6 and a 14mm socket I will check in the morning.
I managed to get an Exmoor trim Locbox from ebay its not the same colour as my trim but I can upholster the lid whenever. 2001 90 TD5 CSW Alveston Red Manual |
31st Jan 2015 7:07pm |
I've managed to get my middle front seat out was quite hard work as 3 out of 4 bolts removed fine. The last one T40 screw head wouldn't budge. I now have 4 holes, do I just put the screws back in will they be loose or are there any alternatives to what can go there? 2001 90 TD5 CSW Alveston Red Manual
7th Feb 2015 9:08pm |
If the nuts underneath were captive just screw the bolts back in if the nuts were loose put them back.
Uncas |
8th Feb 2015 9:26am |
