Home > Maintenance & Modifications > Water in seat box |
NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204 |
Save yourself hours of frustration trying to seal the box....drill a big drain hole 2003 Td5 90
2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
21st Dec 2014 12:18am |
Andyred90 Member Since: 30 Mar 2013 Location: Wantage Posts: 482 |
That's the plan but just wanted to see if there is any reason not to do that before getting the drill out!
21st Dec 2014 9:31am |
michaelwl Member Since: 19 Nov 2014 Location: Durban Posts: 65 |
If you drill a drain hole then this is also a water entry point. So if you do any wading then water will enter and I dont think the computer would like to be covered in water too much.
I would try and find an alternate solution to this problem. 2002 110 TD5 White 1981 S3 R6 Matt Green - Now used as game viewer 2013 Discovery 4 XS |
21st Dec 2014 9:36am |
duck tape
21st Dec 2014 9:53am |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
Try a yrm double battery tray.
http://www.yrmlandrover.com/epages/BT3575..../037B-0001 |
21st Dec 2014 10:44am |
