Home > Technical > Fault Code 4021 ....
Frankie Chou
Hong Kong 2008 Defender 110 Puma 2.4 SW Caledonian Blue
Shocked
Hi everyone, got a question want to share...
My DEFENDER is 2008 PUMA ... the ABS n TC light never turn off.
Diagnostices tellme the Fault code is 4021,which is failure of the Throttle Position Signal -CURRENT .
What i suppose to do? do i need to change any parts?
Thanks
Post #380021 18th Dec 2014 6:00pm
K9F
There is an accelerator position sensor which has 6 wires going to it down by the pedals. Check the connector and it's corresponding connector on the Engine Control Module for starters. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #380027 18th Dec 2014 6:12pm
Frankie Chou
Thank you.. will try it ...
but i have got the other problem is .. when i use the diagnostic computer to clean the fault code.. yes it works, but when i drive the vehicle forward or backward, the TC light always suddenly on and off, also the ABS pump turn on as well.. coz i heard the sound from ABS pump for sure. At the same moment .. the left front wheel is locked by ABS pump, the steering wheel just turn left by itself.... also the break pedal has got vibrateion.
Is it same problem with the accelerator position sensor ?
Post #380038 18th Dec 2014 6:41pm
K9F
Have a look through this thread it may help. Thumbs Up
http://www.defender2.net/forum/topic2394.h...termittent If you go through life with your head in the sand....all people will see is an ar5e!!
Post #380046 18th Dec 2014 6:59pm
Frankie Chou
Thumbs Up THANK YOU SO MUCH!! u got facebook?
Post #380059 18th Dec 2014 8:08pm
K9F
No....Social media apart from this forum I do not partake in. It eats your life. Whistle Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #380078 18th Dec 2014 9:17pm
