Home > In Car Electronics > Aux light switch YUG000540LNF |
Dave Bellis Member Since: 21 May 2014 Location: Shrewsbury Posts: 133 |
Anyone know the current rating of the load contacts of the above switch...hoping to not have to fit a relay for an LED light rated 1.25 A...
Dave |
28th Nov 2014 5:43pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 469 |
The heated seat switches of the same design, switch around 7A - so, this switch should be more than capable of switching 1.25A
You should be aware that this switch switches to earth. There's a wiring diagram, showing how to wire this switch, here - http://www.defender2.net/forum/post6360.html#6360 The design of this switch will cause you problems if you want the switch's tell-tale LED to work, as this is normally fed from the output side of the relay, to pin 5 of the switch. Without a relay, it's not possible to have the tell-tale illuminate when the switch is on. I would suggest that you get a Puma heated seat switch (YUF500150LNF), which costs around a fiver new. Swap the switch front from YUG00540LNF on to the switch body of YUF500150LNF (they both use the Black 5-way switch connector) - and you now have a live switching switch, in which the tell-tale LED is fed from the output side of the switch (pin 4). A diagram for YUF500150LNF can be found, here - http://www.defender2.net/forum/post306063.html#306063 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
28th Nov 2014 7:29pm |
Top man Paul thanks for the info.......all sorted
Dave |
28th Nov 2014 10:56pm |
When used for the rear fog light, it's in conjunction with a latching relay. The function isn't built into the switch.
Click image to enlarge This thread may help: https://www.defender2.net/forum/post723463.html Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
7th Aug 2020 9:45am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 983 |
Latching electronic circuits are available, if you don't need or already have a non-latching relay.
This is for upto 1.5 A: https://www.conrad.com/p/tru-components-sw...pcs-701240 |
7th Aug 2020 8:16pm |
eliteaccess Member Since: 15 Jan 2021 Location: stafford Posts: 2 |
Has anyone come across a problem i have found. I am using the YUF500150LNF defender heated seat switch. I have a wiring diagram showing pin 1 perm live, pin 2 switched live from dash lights, pin 3 unused, pin 4 live switched output to accessory and pin 5, earth/ground.
Everything works, apart from when i push a live into pin 2, the green LED doesnt come on. The amber one works fine as does the switch. I have tried a second switch and the same thing happens. has anyone else come across this? |
15th Jan 2021 5:42pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2623 |
this is something I need to sort on my switches...
15th Jan 2021 7:15pm |
It certainly sounds like it should work Have you tested that you're actually getting 12v from whatever feed you've taken from the instrument lights? Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
15th Jan 2021 8:55pm |
yeh thats the wiring diagram i used. yes deffo have 12v on the input wire for the green backlight.
15th Jan 2021 9:00pm |
Not sure in that case, I'm afraid. As you've tested two switches, it suggests there's something more fundamental with the way that you're making the connections but it's difficult to be more specific. Darren
15th Jan 2021 10:19pm |
