Home > Td5 > TD5 fuel filter housing |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5725 |
Is it possible to buy the clip that the housing cover attaches to on its own? See link below
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...2340564f46 Is the bit in the blue circle (it rusted away) Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
15th Oct 2014 6:08pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Are they not just a Dzus fastner?? Pov.spec,ftw. 2006, 110,TD5.
15th Oct 2014 6:33pm |
1/4 turn fasteners,like these.
http://www.ebay.co.uk/itm/Genuine-Dzus-Mot...1e72f45180 Pov.spec,ftw. 2006, 110,TD5. |
15th Oct 2014 6:41pm |
That looks like the badger - cheers. 1999 Defender TD5 110
15th Oct 2014 6:43pm |
15th Oct 2014 6:44pm |
jhnstap Member Since: 01 Apr 2013 Location: Bournemouth Posts: 73 |
Comes in 2 parts if you just want the cover
Part number WKT100020 £17 from Craddocks I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine |
16th Oct 2014 4:50am |
Podrob Member Since: 20 May 2012 Location: Co Derry, N Ireland Posts: 31 |
I would suggest drilling a small 3mm hole through both flanges and use a small tie wrap to secure. More reliable than the factory catch
19th Oct 2014 9:04pm |
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 134 |
Brilliant timing. I took the cover off mine and then lost the fastener, so it hasn't had the cover on for a couple of months. Can anyone tell me what to select from the eBay options? Stud length is probably the shortest (15mm) I guess, but what about the receptacle? To be honest, I was just going to pop in to the stealership. They're usually helpful, and it will only be a couple of quid for this fastener, assuming it comes separately.
21st Oct 2014 12:26pm |
basher111s Member Since: 30 Oct 2014 Location: Hertfordshire Posts: 1 |
there's a special kit been set up with a black quick release Dzus bolt and clip here
http://www.ebay.co.uk/itm/Land-Rover-Defen...27ef98fe7d |
30th Oct 2014 7:21pm |
Nice one. Thanks for the link.
31st Oct 2014 12:06am |
Turbotcharged Member Since: 03 Nov 2014 Location: Kernow Posts: 29 |
I just bought a new fuel filter...and it came out of the box with a big dent in it...I could take it back it was 38 quid or stick it on...but will it reduce flow ?
3rd Nov 2014 11:41pm |
