Blondie
Hello Ellisboy
I fitted the waeco kit to both front seats my 300 tdi SW a few months back. From memory there were 3 cables to connect, black to any suitable -ve body earth, red is a permanent +ve supply and orange which is a +ve supply switched from the ignition.
I ran the red cable direct off the battery via a 30A in line fuse. The orange off the fused side of fuse 19 air con with a 5A fuse. From memory the cable was rated at 15A but this supply only switches the relays and hence less than the 5A of the fuse (the fuse has not blown yet, the wife and daughter now argue who gets to sit in the heated passenger seat, so must be working)
Hope this helps
28th Oct 2014 11:03pm |
