Home > Maintenance & Modifications > Truck light query |
guessing you still got the dim dip connected ?
think all you need to do is disconnect the resister |
25th Oct 2014 6:00pm |
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 |
Munch90, where do I locate the resistor? Sorry limited knowledge on electrical
25th Oct 2014 6:43pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 598 |
I believe it's under the drivers side front wing
25th Oct 2014 6:54pm |
if its the same as others it's a gold coloured thing about 2 inches long with fins on it riveted to a bracket and a wire out each end going to one plug , just unplug it
25th Oct 2014 6:59pm |
Thank you all will give it a go tomorrow,
Thanks |
25th Oct 2014 7:49pm |
http://www.defender2.net/forum/post314514.html
Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
25th Oct 2014 8:00pm |
Have checked this morning nothing there , mine is a td5 1999 is the location the same ?
26th Oct 2014 11:24am |
did it have dim dip fitted , did the headlights come on dim with the sidelights on (with ign on ) before
a few searches show it right under the wing half way between bottom of aerial and wing vent blank on o/s wing tucked up the top |
26th Oct 2014 11:43am |
any luck sorting it?
26th Oct 2014 4:23pm |
Hi munch90 no luck there definitely isn't a resistor fitted in that location, I can trace the wiring to and from the lights and they don't go to a resistor.
I'm not sure if the lights came on with the sidelights with the old lights. Not sure where that leaves me ? Thanks for the help. Cheers |
26th Oct 2014 5:05pm |
only other thing to look for is a headlight control unit , think its a pink relay in fuse box or in dash somewhere
part no YWC10050 ? resistor could be by brake master cyl looking at another forum |
26th Oct 2014 5:08pm |
Ok will have another go tomorrow, dark now
26th Oct 2014 5:35pm |
might be worth refitting old lights to see if you have dim dip , bit of mucking about I know
26th Oct 2014 5:51pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
i had this on my truck and changed the relay in the foot well for a non dim dip version 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
26th Oct 2014 6:58pm |
