Home > Technical > Urgent worried transfer box question |
rallysteve Member Since: 10 Feb 2014 Location: South Yorks Posts: 2194 |
Sounds like the speed transducer. Has the new transfer box got a centre diff lock as I thought only the models with traction control had no speedo drive as it came from the abs reluctor ring signals. 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread Mobile Diesel Heater Build Thread |
22nd Oct 2014 1:51pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6463 |
It sounds like you are describing the speedo sensor, a hole for which is not fitted to the Disco2 box.
It's just one of the things I also learned about the so-called "straight swap" between the Def and D2 box You will need to swap the housing and brake drum etc onto the D2 box. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
22nd Oct 2014 1:53pm |
that s pain if I have to swap that bit of the housing as I just put a new output shaft seal in it does have diff lock but has none of the rods so these will be swapped over too. It seams like you say martin that's it's not quite a straight swap
22nd Oct 2014 1:59pm |
Can I ask martin, is it just a straight unbolt and swap over or is it a more involved job?
Cheers Ray |
22nd Oct 2014 3:28pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Undo the housing complete with the output shaft and swap the lot over. Easy peasy. You'll also need to swap the front flange as the D2 one is different. Easy peasy again.
22nd Oct 2014 5:32pm |
won't all the gubbins fall out if I take the output shaft out too? I didn't think there would be this many differences on a disco TD5 box.
22nd Oct 2014 7:08pm |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
On a side note, keep me posted on the DMF!
I have a clutch and DMF on the way so will check mine out next week. Also tempted to fit a D2 box to! Sounds like it's just easier to swap the internals over! |
22nd Oct 2014 8:36pm |
Nope, nothing falls out. Done many of them, use a good quality sealant on the mating faces. 20 mins work tops.
22nd Oct 2014 9:16pm |
cheers for that fatboy slim. I've just stripped it, so the garage can swap all the bits over while it's all out and hopefully the transfer box is a good one
Taazz, I'll keep you posted. Hoping to get it back Friday. Cheers Ray |
22nd Oct 2014 10:45pm |
skoller Member Since: 27 Oct 2011 Location: australia Posts: 7 |
Speaking about the speed transducer, does anyone know if its sealed with an o ring or gasket to the transfer box. Mine is weeping a bit of oil and would like to know a little bit about it before I try to fix it. I think I can get to it by removing the plate between the seats.
23rd Oct 2014 12:46am |
Yep, see below:
Click image to enlarge |
23rd Oct 2014 7:36am |
Looks good. Thank you
23rd Oct 2014 9:20am |
All done and fitted and seems good so far
Thanks again for the help Ray |
25th Oct 2014 10:45pm |
