Home > Td5 > Headlamp levellers |
Peter Member Since: 04 Mar 2012 Location: Kent Posts: 153 |
Does anyone know if the wiring loom form these are likely to be present in a 2005 hard top defender?
If so what does the headlamp to motor connector look like and is there a decent installation instruction sheet anywhere. Thanks Peter. BTW disklokuk have offered a 10% discount for the disklok for land rover owners via code lro14 For my post to them showing this http://forum.landrovernet.com/showthread.p...r-Defender |
20th Oct 2014 8:35am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 486 |
Microcat lists different harnesses for 'headlamp levelling' and 'basic' specifications.
If your vehicle doesn't already have the wiring for headlamp levelling, it can easily be added. I posted details of the connectors required, here - http://forums.lr4x4.com/index.php?showtopic=88285&p=760762 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
20th Oct 2014 10:56am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2198 |
Our 02' 110 has the wiring for the levelling in place behind the lamps (plugged into a dummy connector) and also the connector behind the dash for the switch. I was looking to add it onto ours but didn't come across any reasonable priced bowls/motors.
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
20th Oct 2014 2:46pm |
