Home > Off Topic > Problem with petrol automatic Golf... |
Air getting into fuel system or fuel pump failing maybe
16th Sep 2014 10:13pm |
How old is it? If it old enough it may have a Bosch K Jetronic fuel injection system, they were vacuum operated and any air getting in would cause exactly the symptoms you describe. With mine it was a split/rotten servo diaphragm.
The fuel pump can also lead you down the wrong path as the system has a fuel pressure switch, if the switch operates under pressure the pump will not run making you think you have an issue with the pump. Ideally you need a workshop manual or try Googling with a few more details of the exact model, year and what fuel system it has. Good luck. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
16th Sep 2014 10:40pm |
