Home > In Car Electronics > Using a winch solenoid to turn on/off power to a winch |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
The Devon4x4 ones linked are fine. If you compare the rating of the heavy duty Albright winch solenoid and the HD isolator solenoid, the isolator is actually higher rated than the winch solenoid that is being used in competition by a LOT of vehicles without a problem.
The current rating is a bit misleading really, firstly the solenoids' specs show the switching current, not the sustained current and secondly the current draw figures on most winch motors at 12v are VERY optimistic. You haven't a hope in hell of getting a normal 12v vehicle battery and electrical system to provide a continuous 350A to a winch motor. That's why many competitors use 24v electrics with 12v motors as it's the only way of getting anywhere near the theoretical maximum performance of the motor. As soon as the motor starts rotating the current drops and the faster it moves the less current goes through it. If you add together the limitations of 12v cabling, the effective "resistance" that induction creates when the winch motor is moving and the plethora of joints in the circuit (normally at least 10 stud connections and 6 pairs of contacts before you add an isolator) then to get 350A all of those added together need to come to less that 0.04 ohm even if your vehicle system could sustain 13.8 volts in those circumstances. In reality most systems drop to less than 12v when winching commences so 0.03 ohm is more realistic. I've used those isolators on my vehicles for a number of years and never had one fail even when the solenoid at the winch has failed. I use them for isolating winches on my competition vehicle and also for switching in the auxiliary battery and isolating the winch on our overland vehicle. I've used both the HD version and the SU280, both of which have worked fine isolating Warn 8274s with upgraded motors in competition and a Goldfish on the overland motor. http://www.yorkshireoffroadclub.net/ |
29th Aug 2014 11:27pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
Great post - thank you.
30th Aug 2014 6:06am |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
Excellent info Defender 90 XS TD5 (03 Reg)
30th Aug 2014 7:34am |
