Home > Puma (Tdci) > 20k and the faults so far.... |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 |
Here you go, it can be done, go the Tdci
http://youtu.be/MnYoBGV4rvA My Defender and travels |
20th Aug 2014 9:21pm |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
Should I worry? ........... 8 months old and 7k miles - not a single warranty claim to date.
20th Aug 2014 10:00pm |
Yes you should be worried, such little milage in such time, good grief. What kind go Defender owner are you. My Defender and travels
21st Aug 2014 1:03am |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 637 |
Mine is just coming up to 2 years and just over 18k.
It has had the following done: New Clutch and Slave Cylinder Rear Crank Oil Seal Gaskets for Upper and lower sump and Front timing casing New Steering box Oil cooler (engine) plus coolant hoses Intercooler Turbo Hoses (Twice including latest recall) Dash Vent Headlight Switch/Stalk ECU refitted I think I totaled 30 days in the dealers since January. In for annual service next week. |
21st Aug 2014 3:28pm |
yes it can be a worry. Drove mine home from the dealer in the afternoon, and was flat bedded the next morning. They had it for two weeks then I got it back for a week. Then flat bedded again and lost for 5 weeks. Tuff way to enjoy a new car which was my work car as well. Still I was loaned a Freelander 2 which I became quite fond of, and being brand new I showed some respect, but being a tradie I still needed to get all my junk around the place.
When you start to hear these type of stories I am not surprised they want to kill off Defender in its current form. Robots tend not to make the same mistakes a humans. Just weather us humans, or old school lovers will accept the new robot built Defender. I'd assume it will be robot built, as the discussion in this thread is a reality no CEO can't ignore. Od this is, even some of the Freelancers and Disco's I have had a loaners have generated a systems problem dash light occasionally. My Defender and travels |
21st Aug 2014 10:55pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
/\/\/\wot new Defender? Pov.spec,ftw. 2006, 110,TD5.
21st Aug 2014 11:51pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Current DPF issues? |
22nd Aug 2014 8:37pm |
Maml Member Since: 28 Jun 2014 Location: KZN Posts: 20 |
Did he say standard 2,2tdci? Standard as in...just safety upgrades, or standard as in 'racing' standard? Edit: And that's what happens when you type before googling... http://www.bowlermotorsport.com/motorsport/defender-challenge/ Very impressive! |
2nd Sep 2014 1:47pm |
derek Member Since: 13 Jan 2012 Location: Beckenham kent Posts: 94 |
you want to get your self a Harley then you can really spend some cash, service on my Harley is £60 more than my Puma.
D |
3rd Sep 2014 2:35pm |
aage Member Since: 26 Jul 2012 Location: Iceland Posts: 44 |
One brakelight rear, one bearing seal rear right, front seat foam came apart.
Nothing else. Has been almost bulletproof . Love this car. http://www.defender2.net/gallery/index.php?cat=13451 |
5th Sep 2014 2:24am |
Juhulia Member Since: 11 Jul 2013 Location: Dresden Posts: 17 |
18 k so far. Only long distance rides ...
Really nothing - so far. |
22nd Sep 2014 8:48pm |
SupraAyf Member Since: 08 Sep 2014 Location: Durham Posts: 142 |
Crickey, that list is too long. Best of luck with the next 20k, Plodster. That being said, I think Toyota is doing a good deal on Hilux's at the moment - Andrew - |
22nd Sep 2014 10:04pm |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 |
After a few years on non-Land Rover ownership I am now back in a low kilometre 2013 110 station wagon. My previous 2007 Defender had the following replaced in 52,000km:
Clutch at 20,000km. Transfer case output seal. EGR valve 50,000km. My new (used) Defender had 8500km on it when I purchased it over the weekend. Drove it 1000km home that day in which time it would not start after filling up with fuel half way through the trip. On the 4th attempt if fired up so I moved it away from the bowser. After parking for a few minutes, same problem. I think it is either starter or more likely an anti-theft problem / glitch. It is also now leaking from the front differential pinion seal. All I can do is smile! Is that wrong? One bonus is that all panels are aligned very well and no dents in the panels other than the normal unevenness. I have adjusted all the doors so they now shut without having to slam them to close. I am surprised that the 2.2 seems way noisier than my old 2.4. Maybe that is just my imagination. I thought it was meant to be quieter. The dealer rang me to see how I got on with the trip home and I mentioned the few issues I had. The response was "that is what the warranty is for" |
23rd Sep 2014 11:37am |
NT5224 Member Since: 10 Jul 2012 Location: Robin Falls Posts: 50 |
My two cents...
Land Rover 110 HCPU MY2012, currently at 18000 km -not many of them on bituman. -Unidentified rattle from passenger door from delivery (been back twice and 'fixed' under warranty) |
24th Sep 2014 3:35pm |
