Forum · Gallery · Sponsors
Home > Technical > Towing electrics
Reply to topic  Down to end
jst
Towing electrics
Does anyone know if the electrics are already there in say a 110XS or if they fit the loom back from the bulkhead when you go for the option.
IE how difficult would it be to fit my own electic pack? just trailer that is not caravan.
_________________
James
Post #3372 28th Aug 2008 12:49pm
View user's profile Send private message Reply with quote
TJ101
2007 Defender 110 Puma 2.4 XS CSW Manual Cairns Blue
If you order the tow pack, comes with the 7 pin wire kit
If you order without the tow pack,, LR do the kit, but IIRC was under £20, then when up to over £60,, but is only a simple plug in the rear system,, so the wiring is at the rear already !!
_________________
RRS G4, R8, 90 V8 Hybrid
www.wessex4x4response.org.uk
http://forum.innovate4x4.com
Post #3374 28th Aug 2008 1:08pm
jst
got a MPN for loom to plug into the existing one then?
_________________
James
Post #3426 29th Aug 2008 7:41am
TJ101
Last one i had, for a TD5 was YWJ101500, (7 Pin N Type ) can not see them being a lot different to Puma Question
but order on description !
Did send it back, after the price when up 3 fold Shocked
_________________
Post #3431 29th Aug 2008 7:52am
walfy
2007 Defender 90 Puma 2.4 XS CSW Manual Cairns Blue
Not knowing any better I used a gen loom for the electrics. I used the small recess in the rear X member to house the socket. Then fed the electrics up over the chassis rails and into the big multiplug hanging there ready.
_________________
200 TDI 90
90XS Cairns Blue
Post #3452 29th Aug 2008 5:17pm
mse
2008 Defender 90 Puma 2.4 XS CSW Manual Java Black
Green plug under the drivers rear arch - i know whis as when i collected it it was hanging down.
_________________
Mike
2.4TDCi 90CWS XS
300TDi Discovery
Post #3454 29th Aug 2008 6:19pm
jst
excellent thanks guys
Mark - so you just purchased the loom and fitted yourself then?
_________________
James
Post #3464 29th Aug 2008 7:20pm
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2009 Martin Lewis
