Home > Off Topic > Oak flooring |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1756 |
Hi Darren
If it tongue and groove you're better using a floor nailer as it pulls the boards tight (unless manufacturer recommends floating installation) http://www.brandontoolhire.co.uk/en/fixing...ailer.html Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 250D XS |
30th May 2014 10:44pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6264 |
admittedly it was on a concrete floor but I used glue......15 years later and its
don't see why you couldn't use glue even if its not a conc floor. I think the critical thing is to ensure the flooring has 'climatised' ? good luck. |
30th May 2014 11:27pm |
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 |
Is it solid oak or engineered?
30th May 2014 11:34pm |
Mac22 Member Since: 22 Nov 2013 Location: Merseyside Posts: 675 |
If it's solid oak over a sprung floor, nail it. You can hire the tools to fit.
Engineered can be glued (In the T&G) and strapped until set to produce a "floating floor" Remember your expansion gaps and as noted earlier, acclimatisation, more so with solid oak... |
31st May 2014 1:43am |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 |
Thanks for the replies
It's solid oak being mounted straight onto existing pine floorboards. I was going to nail as if there is any problem in the future it's more "recoverable" to be used again after lifting. As I already have an air nailer I am wondering if I can get away with using that or should I use the proper flooring nailer like the bostitch? As I'm doing 4 rooms over a few months it'd probably be cheaper to buy the tool and then sell on after I've finished with it rather than repeatedly hiring. Cheers Darren Darren |
31st May 2014 8:33am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Use the bostich, also need clamps to draw the boards together, as already said get the oak in the room for a week or two this will let it get used to its new home. Just make sure you get the first one straight
Save enough for the back of your Defender Click image to enlarge Original Member Pie n Pea Club. 110 HCPU Tipper |
31st May 2014 8:45am |
The correct nails / nailer is important. Hired kit will give you the correct angle required for good fixings.
You will need something like sisalkraft and possibly a DPM. |
1st Jun 2014 3:38am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Yeah - I used rubber glue (around 4-6mm thick) on a concrete floor, around 5 years ago, and it's been great.
Just fitted 20mm solid oak to my study, and used a primatech nailer - got good results I used 50mm T nails... Can well recommend oak flooring from these guys: http://russwood.co.uk/ Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
1st Jun 2014 7:18pm |
