Home > Td5 > Wiper fault |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
£25 (ish) from Landrover dealer,as usual genuine parts are best. Pov.spec,ftw. 2006, 110,TD5.
22nd Apr 2014 9:44pm |
You can buy them separately (not sure on part number though) only buy genuine as cheaper ones don't last.
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
Examples of prices (no affiliation) 520160 - Switch Park Wiper Motor
Definitely avoid the blue boxes, I replaced the one on our Tdi and had to repair it before I fitted it! |
23rd Apr 2014 6:19am |
kevinf Member Since: 12 Apr 2011 Location: sheffield Posts: 55 |
Thanks for the replies
I had got to that white block on the wiper motor but after much tugging and pulling couldn't get it to move and didn't want to keep trying and damage a otherwise functional wiper motor now I can attack it with more confidence Cheers kevin |
23rd Apr 2014 6:40am |
They take a bit of wiggling to get off, the spring clip locates in a slot and all will become clear once you've got it off
23rd Apr 2014 6:48am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16812 |
The photo above actually is really good for showing how the switch is retained.
The two small pegs you can just make out in the photo locate the switch, and the spring clip holds the switch in place (and the pegs in their holes). To remove, pull the switch very slightly away from the motor to free the pegs, then slide it sideways to release the clip. The first time I changed one it took me longer to get the damn thing off the motor than it did to strip the dash apart to access the motor! |
23rd Apr 2014 8:16am |
part ordered from local main dealer, as mentioned earlier £26 ish plus vat.
any body want a genuine lucas wiper stalk switch as supplied by paddocks only plug into wiring loom once only to discover i'd got it wrong cheers kevin |
23rd Apr 2014 9:11am |
park switch arrived and fitted all faults cured
thanks for all the help! cheers kevin |
24th Apr 2014 11:29am |
