Home > In Car Electronics > Galaxy Tab 3 7" |
I found my Samsung wont charge from anything other Samsung charger when its dead flat , if its still got bit of life in it I can plug in to apple ipad usb charger (using Samsung lead ) and its ok but not if its dead
sorry not tried my blue sea usb on it |
19th Apr 2014 2:10pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
I use the mains charger off an inverter in the car seems to work fine. I never use anything other than genuine chargers for any tablet or phone, i just do not trust aftermarket products with sensitive devices
19th Apr 2014 2:22pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5740 |
I was just using two generic leads that I use for my phone and the wifes phone, which work fine
I have also just tried the genuine Samsung USB lead that came with the Tablet and that does not work. The tablet is 87% charged. Either A) not enough current leaving the BlueSea / Cigerate socket USB convertor B) Tablet uses extra pins for charging that works fine with a 240v plug in charger but not with in car ones C) Other... 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
19th Apr 2014 3:34pm |
Ragerover Member Since: 27 Dec 2013 Location: In a land far far away Posts: 145 |
Not the galaxies but with the ipad it runs different amps then an I phone
I've got a double plug in thingymabob and only 1 side does the pad |
19th Apr 2014 6:00pm |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 253 |
It needs to be 2.1A plus to charge. I bought an adapter off of eBay that has a double output (says it's one for Apple, one for Android), it plugs into the standard Defender socket and works fine. My Disco 'best bits'
Defender 110 XS CSW 2013 |
19th Apr 2014 6:02pm |
mmm shame. I was rather hoping my BlueSea would do the job. Off to hunt the bay of e. 1999 Defender TD5 110
19th Apr 2014 6:45pm |
Just checked the specification of the BlueSea USB socket and the max output is 2.1A
Just tried it on a USB adapter like this http://www.ebay.co.uk/itm/NEW-3-WAY-CAR-US...20d4f189ef and with an output of 500ma, the tablet starts to charge. My thought, is the USB one above might have a different pinout (maybe an extra pin for charging) than the BlueSea one? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
20th Apr 2014 1:49pm |
My mate tried his Tab 3 8" on the same lead and sockets and that charged OK.
But in his car a USB charger he has charges mine but not his! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
24th Apr 2014 1:20pm |
