Home > Camping, Caravanning and Holidays > Stopping the whistle from my roofbox |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 856 |
Camping roll mat?
7th Apr 2014 11:17pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 804 |
Good idea. I was at go outdoors yesterday as well. Another drive over there in the defender won't hurt will it? 2002 110 td5
8th Apr 2014 7:29am |
it must be peculiar to the roof box, wind noise from my hannibal is not noticeable. some racks have an air dam on the front to reduce wind noise
8th Apr 2014 7:33am |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
Take the roof box off
Well it works On a serious not I had the same problem on a roof box that had square brackets, I ended up using u shaped - exhaust clamps - fixings through the box with the fixing inside the box & that seemed to work. You need to ensure the fixing is parallel to the side of the vehicle to minimise wind disruption by the u of the bracket. In my case no whistling 2020 P300 HSE |
8th Apr 2014 7:47am |
timbar Member Since: 30 Jul 2013 Location: Milton Keynes Posts: 245 |
Slightly o/t but we get a whistle from the roof bars because they have an exposed gap at right angles to the direction of movement. Are there any holes in the box floor ... ? 2009 110 XS Station Wagon
8th Apr 2014 10:24am |
Thanks to all who replied. The problem has been solved by putting a camping mat between the box and the rack
2002 110 td5 |
28th Apr 2014 10:07pm |
