Home > In Car Electronics > Bolt on bits RDX LED lights...... |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Yep, simple as that
As long as you order the lamps for later model defenders with fitted plug ... Guns and Landrovers .... anything else is irrelevant. |
5th Nov 2013 12:44pm |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2297 |
waiting for my new RDX LED brake lights to arrive in the post as I'm simply fed up of my old leaky units blowing the brake lights out all the time!
the others will get replaced with the RDX ones as and when they break! 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
5th Nov 2013 1:03pm |
Trevor Wright Member Since: 11 May 2008 Location: Essex Posts: 87 |
I wondered about the RDX-supplied adjustable 4-pin flasher relay in use with a variety of trailers, most of which will have bulbs but I guess some newer ones may have LEDs. Does having a 13-pin Euro trailer connector make any difference one way or the other? And what about the situation when the MoT tester plugs in the trailer connector test box to check your trailer electrics?
Anyone with any practical experience? or can the supplier come back with an answer. Thanks for your advice. Trevor Wright '08 90 TDCi/TD4 XS SW Last edited by Trevor Wright on 6th Nov 2013 8:13am. Edited 1 time in total |
5th Nov 2013 2:13pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5408 |
"For a 2008 TDCi 2.4 Puma, is fitting these RDX rear red stop/tail and white front sidelights simply a matter of unscrew, unplug, plug and rescrew - literally that, or is there some other little wrinkle to consider?"
For most the lights that is all you have to do. BUT you will need to fit new indicator relay, which is very very simple on the Tdci. And some lights require the connectors crimping on, again very simple. Andy |
5th Nov 2013 8:19pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Did the lot this afternoon. 1 hour + cup of tea. Full easy to follow instructions. They are bright!!! LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
5th Nov 2013 8:42pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Thought I had an indicator bulb out, but have discovered this morning that the bulb holder has actually melted and deformed - that's what you get for buying lamps that come in a blue box! So think I will be buying a set of these - I was planning to get some anyway.
I'm guessing these are the Wipac items? Just being resold by LRX? Had anyone explored buying them from Wipac direct and what the price difference is? I notice they are listed on the Wipac website along with a Wipac relay. Also - could anyone confirm that the indicator relay in a Td5 is behind the instrument panel? Really handy place to get to! 2005 Td5 | 90 Station Wagon | Tonga Green |
6th Nov 2013 10:04am |
I don't know whether these are RDX original items or sourced from elsewhere (maybe the same place as Wipac), but if you look at RDX's eBay entry for their flasher relay:
http://www.ebay.co.uk/itm/230952858198 they do make comments distinguishing the Wipac relay capabilities from their own design. Trevor Wright '08 90 TDCi/TD4 XS SW |
6th Nov 2013 10:51am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19452 |
The link supplied above has some excellent info on it about the RDX relays, in fact everything really that you should need to know. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️
And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
6th Nov 2013 5:57pm |
RickH Member Since: 25 Aug 2013 Location: Central belt Scotland Posts: 39 |
I'm having some interesting times with the RDX indicators and relay. The relay isn't working right or my TD5 has something interesting going on with the wiring (see my other thread). Still, bolt on bits are being helpful to understand the issue so can't complain.
8th Nov 2013 8:33pm |
I like the idea of a full set of these but there are two issues that out me off currently.
1. A bit concerning about the trailer issue, most use incandescent lighting still not LED and even if they do or you have them they will be expensive. They say on their page it isn't an issue regardless, so anyone that can clarify that? 2. They've done really well to make a quality set but including connectors and such like, it's a shame the fog and reverse would have to be cut into. Yes, I could just leave them but the complete set would have been nice. But using all plug and play connectors. I really do hate cutting into wiring if I can avoid it where ever possible. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
10th Nov 2013 3:41pm |
They did say that they were working on a version of the fog /reverse tbat comes with connectors. Plus a new version of the led relay that had more functionality. Personally, I'd like the basic one to work for me.
10th Nov 2013 5:14pm |
I have full set of these complete with their relay, and all is ok when towing trailer using standard bulbs.
My fog and reverse lights both came with connectors, would not have bothered me if they didn't, but just had to attach them from memory, and that is simple as crimp and poke. Andy |
10th Nov 2013 5:19pm |
Andy, was the flash rate similar between both despit the combo of incandescent and LED? Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️
10th Nov 2013 5:35pm |
No. The flash rate with LED is much slower, and remains at this speed with trailer attached.
Andy |
10th Nov 2013 6:36pm |
