Home > Tdi > anti roll bars |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
Hi all. Quick question. Did all late 300 commercial 90's have anti roll bars as standard? Rhubarb and custard let fly with their secret weapon.
4th May 2012 4:09pm |
mine doesn't - could do with some
4th May 2012 4:54pm |
An option then. Goodo. I will look at binning mine then, see if that helps with wheel lifting tripod action. Rhubarb and custard let fly with their secret weapon.
4th May 2012 8:20pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
no need to remove them for greenlaning in the uk. only if you're doing pay / play or events.
26th Jun 2012 11:18am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7683 |
i have a set here, front and rear off a 110 08 plate and a rear off a 10 plate 110 up for grabs. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
26th Jun 2012 9:42pm |
I do neither of those trhings. But I can report I now seem able to keep all my wheels on the deck even where before I had two wheels off not now. Rhubarb and custard let fly with their secret weapon. |
1st Jul 2012 12:36am |
James - sorry I missed your post... 1. would they fit a 95/300/90 ? 2. how much would you like for them? |
1st Jul 2012 7:16am |
i believe so yes. fronts are def would need to check on the rear. you after front and rear? will double check where the are and get some dims/pictures if you want? price wise, dunno, what they worth to you? ie make an offer. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
2nd Jul 2012 10:23am |
hi James
yes, front and rear please ... I'll PM you an offer |
14th Jul 2012 7:33am |
Lookers Park Royal Member Since: 19 Jun 2008 Location: London Posts: 338 |
I have ARB's on my 90 300 Tdi which was a pick-up, and do a fair bit of laning and RTV trialing. To be fair unless you are looking for excessive articulation then you'd probably be fine with them fitted.
I would rather have them on for all the benefits of on-road cornering and compromise with a bit of wheel lifting off road. James |
14th Jul 2012 1:01pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Concur with James I fitted front and rear to my 90 about 3 years ago as it was a bit 'wallowy' on the road .. what an absolute difference! Drives so much better, and not noticed any difference when laning/off roading - still go's everywhere it did before Guns and Landrovers .... anything else is irrelevant. |
14th Jul 2012 1:34pm |
SteveRat Member Since: 01 Aug 2012 Location: Chester Posts: 7 |
I'm also in the market for ARBs. My 94 county 90 has the mounting points but no ARBs - so pls let me know if you have a spare set you want to flog. I use mine for towing and feild work but nothing extreme, I just want to cut down on the rolling in the corners.
Cheers Steve |
1st Aug 2012 10:11pm |
