![]() | Home > Td5 > TD5 unburnt diesel on startup. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 ![]() ![]() ![]() |
10 or 15P engine?
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 254 ![]() ![]() |
ok so finally did what I should have done after i installed the new head gasket.. Bought a CO/2 testing kit and ... after 35 mins of fast idle, still got CO2 in the coolant so there is still a leas past gasket or its the head.
Have another head so will take it for checking st a machine shop then if its ok install that . Failing that could be buying a new head A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1544 ![]() ![]() |
i was about to ask if you had the head skimmed and pressure tested....
unfortinately not the 1st time ... will be b4 i change the gasket again
Leaking down over night cracked head or bad gasket job. Only if it was 15P it could be cracked in the injector socket.
Annoyingly, some times fire it up and not a peep of white smoke. e.g. last time she ran ( 2 weeks ago) clouds of stuff. ran her for 35 mins
went out just now, turned the key and starts fine not a peep of the stuff everything seems normal As its the 1st td5 head gasket ive done will happily admit it could be my fault but would realy like some consistency please! A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
Next question though. The instructions for the CO2 testing kit says "Run for a few mins" ok how long is a few mins.... took 35 mins at idle with occasional foot pressure to get from blue-> green-> yellow
If I'd run it for 5-10 mins it would have said things are ok Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
Until it’s operating temp, I guess the thermostats open, which is hard to do on a td5 at tick over. Do you only get the white smoke on start up and after an extended period of sitting ie overnight? What year is your td5?
