Home > Puma (Tdci) > MAF sensor failure Puma |
Doodlefish Member Since: 18 Nov 2021 Location: United Kingdom Posts: 54 |
What is the fault code?
1st Jun 2022 9:22am |
Bantus123 Member Since: 12 Feb 2022 Location: Cataluna Posts: 3 |
It was the P0110
1st Jun 2022 10:45am |
Okay so I am not sure if the MAF sensor and MAP sensor are separate on the 2.4 as I have the 2.2 which are separate. I changes both sensors. I would advise changing your air filter as well. Once the ECU is clear of the fault code you might find this solves it and its not hugely expensive and easy to do.
You can check out my thread on the issues. https://www.defender2.net/forum/topic81269.html https://www.defender2.net/forum/topic81732.html Good luck. |
1st Jun 2022 11:11am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19750 |
MAF and MAP are separate on the 2.4 also.
Sometimes other things trigger a nuisance MAF code which if I remember rightly that one is. The EGR is one culprit that has been known to trigger a false MAF DTC. Do you have a Rai or Snorkel? If so some people have had false DTC’s with the MAF because of that ongoing and just clear it. I haven’t with mine but I have heard of it. Try modding the air box base for better air flow if this is the case, and a new air filter as mentioned and go from there. Also have a quick look at the wiring from the MAF plug. Sometimes the wiring there can break and some people have had to replace it due to this. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
1st Jun 2022 1:59pm |
Hello again,
in the end we had a look at the EGR and replaced it. Error is now gone for 500km+. Thank you very much for your help. |
15th Jul 2022 7:21am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2291 |
Gents
I have no idea regarding the MAF and fuel figures at idle and around 10 Celcius. I am posting a picture of the 2.4, so please jump in if you reckon the airflow numbers look ok. Thx Click image to enlarge PS. 23.93 is the last number in case you cannot figure it out. Puma 110" SW ............................................................. Earth first. Other planets later |
14th May 2024 1:51pm |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 325 |
Not sure what your figures relate to..
Your ambient air pressure should relate to about 1 bar (14.7psi).. At tick over you would see a boost pressure of about 1 psi giving a manifold pressure of about 15/16psi.... The maf at tick over about 16gs.. Your fuel rail pressure of 23MPs would be about right for tick over.. Ie 3300psi Not sure what the fuel rail sensor voltage is about... 23.93🤔 |
14th May 2024 2:12pm |
OK.
According to your suggestions looks the manifold pressure is lower than the atmosheric pressure. All other figures look ok. I am having a smoke problem, therefore. It only goes away when the engine is very hot. Not at 50, 70 or 80C, but close to 90C. Puma 110" SW ............................................................. Earth first. Other planets later |
14th May 2024 2:23pm |
But what do 88 and 91 referee to.. If its kpa that doesn't make sense.. If 1kpa is about half a psi, or 0.45 psi..
14th May 2024 2:29pm |
Sorry.. Just checked.. 1kpa is. 0.145 psi..
Don't know where I got. 45 from😩😂 |
14th May 2024 2:32pm |
Right. IIRC the MAP will read less than the actual ambient pressure due to vaccum. Not sure though. Puma 110" SW
14th May 2024 2:43pm |
I have never seen my boost pressure ie mamifold pressure lower than ambient even on tick over.. There is always a slight increase..
But if you have an active egr system I suppose it may be possible that the electronic throttle will close slightly to aid egr.. And you could see a slightly lower pressure👍 |
14th May 2024 3:20pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2247 |
Just for absolute clarity which sensor are you referring to?
The one on the airbox or the one just near/beneath the injectors? > 110 XS Double Cab > Instagram @simonlanemind |
14th May 2024 5:13pm |
I am assuming the "Air flow KPA" number, refers to the MAF. Puma 110" SW
14th May 2024 5:19pm |
